Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
Had to start with the dashboard modifications to figure out how many resistors I need on the front resistor board. Added some switches and backlighting for the reverse cam display and instrument panel. Green LEDs for turn signals.
![]() ![]() ![]() Final design for the front resistor board. ![]() Started working on the floodlights for the telescopic light mast. A lot of guesstimation based on photos to get the dimensions and angles right, but I feel it's pretty close. Mostly 1mm styrene. 5730 neutral white LED soldered to metal strips in the hope that they will move some of the heat to the outside. ![]() Of course one broke when bending the metal strips ![]() ![]() ![]() I swear I tested them all before filling them with CA glue! Only tested at low power though. Turns out that when tested at full power for more than a minute one of them started blinking. Most likely damage from soldering. Always fun to carve out fully cured glue. ![]() I was hoping to run them at 60mA each, but I'll stick below 40 as I'm a bit concerned about heat buildup and don't feel like replacing any more LEDs in them for the next decade. I think they're bright enough anyway. ![]() |
