Old 12-28-2018, 08:46 AM
Default Re: CAT 14M3 Motor Grader
I got the wheel lean cylinder done today.
Old 12-29-2018, 10:16 AM
I was making the steering cylinders today. The wheel lean function makes the job a bit harder as you need to have ball joints on both ends of steering cylinder. The piston diameter is 8 mm.
Old 12-30-2018, 09:03 AM
I got the steering cylinders mounted to the axle
