Old 01-01-2019, 01:42 AM
Default Re: Starting a new build... something...
Very cool project! That looks fun.
Each track drive motor only needs an esc, it doesn't need a servo also.
If you want the lights on any time the models turned on you can tap RX voltage and not use a channel to turn it on/off. If you want to switch lights on/off from the remote, check out the links wombii posted.
This will be fun to watch
