Old 01-05-2019, 03:24 PM
ChILd_ReBoRn ChILd_ReBoRn is offline
ChILd_ReBoRn is on a distinguished road
Default Re: Battery capacity. What's nominal?
And swap them when one is depleted?
I have some 18650 cells lying about, I'll solder them in 3S configuration and use it for testing purposes. If they suffice, I'll order a dedicated LiPo pack(s).
Old 01-05-2019, 06:43 PM
The 18650 batteries are not designed to handle the discharge rate(s) that may be put on them. For a test they should work one or two times.
As Joe said TWO 3000MAH batteries is good. That way you can have one on the charger while you're running the other.
