Old 01-20-2019, 11:52 PM
DADSGARAGE's Avatar
Default Re: PC1800 Front Shovel (1/12)
The new plan was to incorporate some small 1/8" quad rings to act as seals but decided to go with o-rings instead. (less contact area making it easier to turn)
The "inner race ring" will be installed upside down and an o-ring added to seal against the inside face of the shoulder that supports the 100 - 1/4" balls on the stationary outer race. (Sorry the photo shows the quad ring)
A new taller top spacer ring was made with an o-ring installed that will seal up against the ID of the sprocket.
The new top spacer ring also needed to be a bit bigger in diameter to match up with the original ID of the sprocket.....Yikes....just enough clearance for the balls once the angle was cut on the spacer.......fun fun......more obstacles!!
Old 01-21-2019, 12:14 AM
DADSGARAGE's Avatar
This is the order of how all this mess fits together....LOL...still need to drill the holes in the new top spacer!!
Hopefully this will help someone else get ideas on building a swing bearing from scratch!! One thing to remember is that the rolling elements (balls) are only running on a flat surface and not on a radius. Because this bearing only has point contact on the balls it will most likely wear a bit faster.
Thanks for looking!!
KP
