I put new teeth on my digging bucket June 2015, I was noticing the other day how much they've worn... same narrow teeth as the 450 bucket... about 4mm shorter now.
![]() ![]() Sharpened them up with the side grinder this morning ![]() Getting the south side soaked up to chimney this week. ![]() North side has been drying the last 10 days, now I can drive on the surface & not gum up my tracks with muddy clay. ![]() Ripped a straight edge. ![]() Start the next cut trying to keep a level bench. ![]() ![]() Getting some screening done. ![]() Do some crushing next month, if the lumps are dry enough that it doesn't clog up my crusher plates. ![]() Did some hauling a few days ago, my mod with re-powering the B50 axles didn't work as well as I had hoped, get a lot of weight on the center axle & it still doesn't have enough umf!! to get over the hump. A thought just come to me now... center axle is Slave on the mix, so maybe if I jack it to 120% so center axle pushes harder ![]() ![]()
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
