Bummer to hear the re-power option wasn't as effective as you'd hoped it'd be.
Been playing with the settings again today & still not getting the even pulling power from the brushed motors anything like the brushless... keep tinkering.
Finished up the north cut yesterday ![]() This'll be the last pass in the NE to do, next month maybe ![]() Today I worked at cleaning up this big mess under the stairs ![]() ![]() These rocks to go to the crusher ![]() These rocks go to the pile in the lean-to, to be hauled away in my Ranger this summer. ![]() Used the lowboy too to cart out these cement blocks & wood ![]() Load too heavy for 8wd, had to give it a push by hand some of the way ![]() This load of rock was too heavy for the brushed motors, had to give it a helping hand up the dirt ramp too, but the trk backed up the steep crusher ramp on its own... making me wonder if I reverse the motor leads on the Sabertooth, reverse direction in radio programming, maybe I'll have more power going forward then ![]() ![]() ![]() Brushed trk got demoted to garbage hauler ![]() Brushless trk hauled the next 6 loads of rock out to the crusher ![]() 7 trk loads ![]() Used the 450 bucket to hand bomb a sample into the mini crusher... an rc activity for the JD450 next week. ![]() ![]() ![]() ![]() Gonna try & break these cement blocks with the Premacon jackhammer using the newer JD850, it has a 4th valve in it, just need to make a quick coupler plate to mount it. ![]() The 1st load of rock, I started to dump half the load into crusher & jammed it about 10 seconds, had to dig all the rocks out to get crusher moving again... dropped the rocks in by hand a few at a time after that. Made a couple vids while I was at it. https://youtu.be/OlP8omrQM-0 This quick vid, one really hard rock that I was playing catch with... and the last rock jammed & I stopped the vid. After I got the rock out, I dropped in again & it broke right away... https://youtu.be/ZEEavvckpcw
Currently Active Users Viewing This Thread: 26 (0 members and 26 guests) | |
