Old 03-06-2019, 10:22 AM
Default Re: LilGiantsConstrCo
I spent the weekend carving out the 2nd pass on SE corner
Some problems with the 850 that have been increasing over the last couple weeks... too much freeplay in the swing, erratic power in the tracks & a hydraulic leak... stripped it to a lot pieces yesterday & made a shopping list sent to Frank this morning.
Need a new slip ring
New wiring... green oxidizing on the wires & they're pretty stiff too. Checked resistance, 1 to 2 ohms.
Set screws on pinion gear came loose, but also a lot of side play in the planetary shaft again... gonna try using a 6x15 ball bearing in place of the hard bearing.
But before I take that apart I try to figure out the hyd leak... some where in the front to do with the boom cylinders... either a bad seal on a fitting or a pin hole in one of the lines or ? ...what a greasy mess in a tight area to clean, lots of electrical cleaner, pressurized air & towels
While waiting for parts from Germany, lots of other dirt work to do
big pile of dirt to haul out from SE corner
another pile from NE
I hope to have my track hoe back together in two weeks to dig this up on the east wall
...hope for the arrival of Spring in a month to get busy farming, last yr it didn't come till Arpil 20th, then a mad scramble through May... I hope it comes sooner this yr.
Old 03-06-2019, 10:53 AM
Joe, your equipment looks just like the real stuff - a leak here and there with oil saturated dirt, worn parts from extreme use, and parts ordered from the manufacturer. Still amazed at the quantity of work you complete. I agree with Cooper, your crushing & screening operation would be the envy of any real company.
Keep on diggin'!
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
