Old 04-28-2019, 06:16 PM
Wombii's Avatar
Wombii Wombii is offline
Default Re: most realistic radio operation for semi?
I think switching the function of one stick axis between throttle and brake would allow for some unpleasant accidents depending on where the stick is when you switch. It might be safer to use up/down on the stick for throttle and pull left on the same stick for brake. Seems like that would be possible by programming 0-100 of the throttle input to control throttle output channel 50-100 and brake input channel 0-50 to control throttle output channel 0-50. Maybe add a special mix function to limit throttle output channel to 50-100 unless throttle input channel is 0, so you can't brake unless throttle is at the bottom.
I don't think you can set up the hardware to be spring-loaded from the bottom instead of center though?
