#101
I've already watched your snow work videos, great work. I love the working windshield wiper ![]()
#102
#103
That blade looks good!
#104
#105
#106
Beautiful work
#107
Great work as always!
#108
#109
Beautiful work!
#110
Hi guys, it's been a while since last update.
I've been drawing the cab and the engine enclosure, and those parts I was thinking to 3D print. You who have used 3D printer for parts like those, how would you print them ? Do you print it wall by wall flat the build plate, or how would you do it ? I got some machining done also. This is the rear sub frame for the ripper ![]() I was trying to upload these pictures from Photobucket, but no matter what I did they showed up on the original size ![]() ![]() ![]() ![]()
#111
#112
#113
#114
#115
How I'd print the cab would depend on the size of it. IF it was small enough I could get in on my printer in one shot, I'd try it that way first.
#116
That would be the easiest way, I'm just a bit bit worried about how the window openings will turn out.
#117
I made the first side wall for the engine enclosure. It's quite awkward shape as it get wider at half way and the upper front corners are bevelled, due better rear visibility.
#118
#119
ola boa tarde muito impressionante todo seu trabalho eu gostaria de ver um vídeo destas soldas é possível você fazer um vídeo de como você faz estas soldas?
#120
https://www.youtube.com/watch?v=YoXMCrlaGT4
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests) | |
