Old 07-28-2019, 05:44 AM
kingbob kingbob is offline
kingbob is on a distinguished road
Default Re: Movie Optimus Prime build
Originally Posted by James007 View Post
Hi bob, can I ask what you used for the rivets on the body ? Thanks
I actually used pinheads. Drilled small holes with a pinvise, put the pin through and glued it, then cut off the bit inside.
If i was to do it again though, i wouldn't do it that way. Externally it looks fine, but inside even with the pins cut, theres lots of sharp bits and i cut myself many times, and it can scratch parts when putting the body on.
Now i'd probably just use some round head resin rivets. Not as cheap as a pack of pins, but neater internally.
Old 08-01-2019, 01:25 AM
James007 James007 is offline
James007 is on a distinguished road
Thanks for the information bob, can I ask what’s the best glue to stick the body back together, I’m planning on cutting my sleeper down so I’d like to know what the best stuff to use would be, I was thinking loctite superglue?
Thanks James
