Old 10-01-2019, 02:21 PM
Default Re: last thing left i hope
Go to MIX in radio programming
Mix 1
first channel entry is valve & second channel is pump.
Then there's the + - 100 values, the order of + or - depends on how the pump wiring is configured. If you are getting pump motor speed up but no pressure, then the pump motor is turning backwards, reverse the + - 100 values
Then select the ch that is your Mixing switch
Mix 2 next valve ch 1st & pump motor ch. then the +- 100 values in correct order, the mixing ch
Mix 3 next valve ch, pump ch & +- 100 values in correct order, mixing ch
That's it!
As you open even one valve, the pump motor will speed up.
It's beneficial to have your hyd motoring always turning because to start/stop pump motor heats up the esc to point where it could burn out stop working or worse, catch fire. Adjust EPA on pump ch to30%
