Old 01-31-2020, 04:25 AM
Default Re: Newbie Scratch Build - D575A Dozer
What diameter is your drive sprocket?
Old 02-01-2020, 03:19 AM
The sprocket has a 105 mm pitch diameter. I did a crude test with the sprocket straight in the motor and it looked too fast. 🤷🏼‍♂️
Is there an easy way to make it 2 speed?
Old 02-02-2020, 03:23 PM
So a little progress has happened since last time...
One side of the track links are complete ( awaiting metal to machine pads). these take so long !
Had some stock delivered for the idler wheel and roller wheels. will start machining over the next few weeks to size
Started the idler wheel …
Quick question on electrics if anyone can help ?…
so I am planning on using a 24v battery, running 24 volt motors which is easy as the sabretooth controller can take that voltage but what happens if I want to use a Premacon 12v hydro pump in the system - does anyone know what I need to reduce the volts for the pump?
should have some more pics of the track carrages over the next few weeks once the metal turns up
Cheers
Rob
Old 02-02-2020, 04:48 PM
crueby crueby is offline
Those track links are looking great! Where did you get the laser cutting done?
Old 02-02-2020, 05:52 PM
Smile Re: Newbie Scratch Build - D575A Dozer
I found a relatively local engineering shop that supplies all sorts of metal and cutting services. I have found that although laser cutting is fairly accurate, it still leaves me with a lot of work to bring the items to an acceptable finish. Laser cutting also leave poor edges and seems like it also hardens it?
Its still a lot better that cutting 10 mm plate steel with a hacksaw so I wont complain !
The round stock and flats I get from another supplier. I just send the diameters I need and lengths. I can use my lathe and mill to do the rest.
One day if I get space to do so, I would like some sort of cnc but for now its all manual
Old 02-03-2020, 04:55 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Rob
Why not get the pump without motor from Premacon and source a suitable 24V motor? Probably easier than having to find room for a voltage converter.
Nice project you have going!
Old 02-15-2020, 06:07 AM
Of course! That sounds like a great idea !
