Old 03-03-2020, 08:43 PM
Default Re: Nylint michigan crane conversion, hopefully
Couple months ago I finally got around to epoxying lead shot into the back of the house about 1/4" deep. Probably in the 1-2 lb range. It helps, but i probably still need to get a thrust bearing, fender washer, screw, drilled&tapped pivot post...
Then reccently some people here were talking about clamshell buckets again, so i thought why not try to convert a Nylint clamshell bucket, using as much of the stuff removed during conversion of this Nylint. What could it look like if the factory were to have made one more complicated?
This uses the original tip mounted Hoist line pulley moved to the top between the 4 links, brass axle with lifting loop, and a cable guide with a W shape. Then the Boom angle pulley was removed from its bracket and installed with spacers at the bucket fulcrum. The buckets closer line ties off to the top axle, runs below the bucket hinge, then up around the top pulley, to the cable guide and a ring where the Crowd line attaches.
Then i ran a Calming line from one of the buckets links, around a pin on the boom, to a fishing weight. It just needs enough weight to keep the bucket from rotating and tangling the lines, and enough length for the needed travel.
