Old 04-04-2020, 12:47 AM
Default Re: HIAB X-HIPRO 1058 loader crane
Originally Posted by BlackCat View Post
Nice work Hemi !
You make me want to try milling some of those steel sheet on my cnc router. What’s your feeds and speeds for a base guide line ?
For the contours I'm running at 300mm/min, and fairly small cuts, around 0,3-0,4mm. The main problem is heat generation, I only have a mist coolant on my machine, so it's not as effective as proper flood coolant.
Old 04-04-2020, 08:09 AM
Here's a few pictures of assembled crane
Next I should probably start making the telescopic arm.
Tags
hiab, loader crane
