Old 04-25-2020, 11:56 PM
Default Re: HIAB X-HIPRO 1058 loader crane
I studied how they arrange the oil delivery to the extension cylinders on the full size crane, and I realized they come up with a clever solution.
The oil is run trough the piston rod to the next cylinder. There's apparently two holes running all the way inside the rod from each side of the piston and out of the the top of the rod. If you look closely at this picture you'll see what I mean. There's no rubber hoses, just hard lines.
Unfortunately that's not possible to accomplish in this scale, the rod is only 4 mm thick and over 150 mm long. It would have made everything so much tidier
Old 05-02-2020, 11:39 AM
I got all the extensions done
Old 05-17-2020, 12:23 PM
Some progress with the crane
Old 05-17-2020, 03:04 PM
As usual, a most astounding display of craftsmanship! Your welding machine certainly makes putting the pieces together easier and neat. Awesome!
Old 05-24-2020, 10:10 AM
I got the parts for the extension cylinders done. The o-ring grooves on the cap for the piston rod sealing were quite difficult to machine as the hole diameter is only 4 mm. My grooving tools minimum hole size was 4,1 mm, so I had to do some grinding to get it fit.
I also got the rest of the cylinder brackets machined.
Old 05-24-2020, 11:25 AM
Great detail and precision!
Tags
hiab, loader crane
