Old 05-02-2020, 11:39 AM
Default Re: HIAB X-HIPRO 1058 loader crane
I got all the extensions done
Old 05-17-2020, 12:23 PM
Some progress with the crane
Old 05-17-2020, 03:04 PM
As usual, a most astounding display of craftsmanship! Your welding machine certainly makes putting the pieces together easier and neat. Awesome!
Old 05-24-2020, 10:10 AM
I got the parts for the extension cylinders done. The o-ring grooves on the cap for the piston rod sealing were quite difficult to machine as the hole diameter is only 4 mm. My grooving tools minimum hole size was 4,1 mm, so I had to do some grinding to get it fit.
I also got the rest of the cylinder brackets machined.
Old 05-24-2020, 11:25 AM
Great detail and precision!
Tags
hiab, loader crane
