Old 01-21-2011, 07:16 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Default Changing Hydraulic Oil
I'm hoping that some of you guys can give me some advice on how to change the oil on my Leimbach Excavator.
I took some pics of the hydraulic system and labeled each connection to make this a little easier:
1:
2:
3:
4:
5: Reservoir Breather
6: Reservoir Breather
7:
8:
To, it looks like fluid is pumped from 2 into the filter at 4, out of 8 and into 7 to the value body.... then out of 3 and back into the pump at 1. !!!
My questions are:
A. What line do I remove and put into my new fluid?
B. Do I need to service the filter?
C. I assume I also remove the reservoir and put new fluid in
Or, a better way, is how do you change the oil in a machine like this?
East Coast Mini Truckers
