Construction Equipment Tech Hydraulics, Electronics, General Engineering, ect in constr equip |
Hey any one got some ideas to replace hydraulics in my dozer ? I'm thinking I can get away with something other then hydraulics. Just looking for ideas. Let discuss it lol
www.actuonix.com
This dozer uses dual 30mm stroke 50:1 L12-S actuators. Make sure to get the S series, as it takes an esc to operate, giving you infinite height adjustment. The R series plugs directly into the rx and works exactly like a servo, as in if you put it on a stick ch, when the stick centers so does the actuator at mid travel. https://youtu.be/5k-rGA7GCZU
Thanks, I was thinking of thoughs , I'll see what my money looks like
Probably not the answer you were looking for but I'll put it out there just in case. How about doing an old-school cable dozer instead? No hydraulics needed. Only a winch which could even be a servo. Here's an example:
(Click the image to see full-size) ![]() Hope this helps...
Brian Finster shavin' and smokin' a cigar?!?! |
I've been thinking about these ...a really different build the dozer is kind of pricey to hack up...but..
https://www.3000toys.com/Spec-cast-C...-CASTCUST-1432 |
I know i'm weird and like old stuff, but those cable dozers look really cool!
Good thing i'm not in the market for a dozer right now, that one looks great jerry. (Do it.) The cable reeving on that top one might get a little confusing, but with that much compounding a servo winch should have plenty of power to work with if the blade is heavy enough to not float.
Well my dozer is already built and hydraulic, I was just looking for something different, the hydraulics are becoming a pain .
have you thought of trying the actuators they sell on ali express for the huina excavators? servos already attached to lead screws https://uk.banggood.com/Huina-Plasti...iABEgI6jfD_BwE
if the servos aren't strong enough you can take them off and attach gearhead motors |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
