Old 07-01-2020, 08:33 PM
Bo Wallen's Avatar
Thumbs up Re: KH Beam Hauler
Thank You, Nick. I have a good feeling about your project. I will Have your product Incorporated in my fleet. The original Tamiya axles are right, and if they get tuned tight when built, they will last a long time. I have axles with far more than three hundred hours on them, still running smooth. So let's have the two current Mercedes on the bench run your front axles.
I am looking forward to working with you. Nick.
Old 07-01-2020, 08:45 PM
NRS91 NRS91 is offline
NRS91 is on a distinguished road
Default Re: KH Beam Hauler
I currently have 1 pinion out of 6 which jumps out of mesh, it's a different design to the other 5 on the 8x8 so not sure where it's from but will add a circlip or washer between the gear and bearing then full testing can commence!
Thanks
Nick
Old 07-02-2020, 12:03 AM
Bo Wallen's Avatar
Exclamation Re: KH Beam Hauler
The Mesh is extremely important on casted gears; There is no shortcut at that.
However, Tamiya does not make metal parts in the house. Therefore the gearbox has two different pressure angles on the gears, Old standard and new. Witch makes the gear to go down faster than it would with the same pressure angles. Now Japan is a monoculture, so the boss does not know that, and a new gearbox or axles will not be on the horizon for some time. But the work so I stick with them.
Old 07-02-2020, 06:10 AM
Yea its very odd all the axles ive built so far have been spot on besides that one pinion that has free play but ill get it sorted!
Thanks
Nick
Old 07-15-2020, 03:52 PM
Bo Wallen's Avatar
Just came across this site again. Over Milion's views. https://www.youtube.com/watch?v=NNVn8fLy5Ro
Old 08-03-2020, 05:51 PM
Bo Wallen's Avatar
Lightbulb Re: KH Beam Hauler
Today I started designing the solution for the weakest part in the gearbox, Hope it will work as good as I hope.
[IMG]IMG_6268 by Bo Wallen, on Flickr[/IMG]
Design and Machining, my self. Hardening outsourced.
[IMG]Screen Shot 2020-08-03 at 10.55.25 AM by Bo Wallen, on Flickr[/IMG]
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
