Old 07-22-2020, 08:01 PM
Default Re: First attempt at lights
First idea was just cutting the power input wires about 1" long, and bridging them on the switch pcb with the solder pads where red & black wires from RX connector mount. So you keep 1 rx plug, 1 output
Second idea was if you put another servo lead connection onto the power in wires, you'd have 2 plugs to mount into rx. Original 3 wire plug to whatever channel, 2 wire to empty channel or bat / vcc.
To tag on to 9ws suggestion, If you've got any junk or cheap servos, and 2 matched value resistors you can do the same switching as an esc in smaller footprint.
