Old 07-26-2020, 11:05 PM
Default Re: HIAB X-HIPRO 1058 loader crane
Originally Posted by ddmckee54 View Post
Did you say you were going to use a sequencing valve, or that you didn't plan on it? Without a sequencing valve, whichever section moves the easiest is gong to be the section that moves first. Path of least resistance and all that.
Don
I don't think there's room for sequencing valves. They should be located on the boom, or other wise I would need a ton of more tubing. I can adjust the movement sensitivity on each segment with a nylon set screws though. They are meant to adjust the side play of the segments. Will just have to wait and see how is going to work.
Old 08-15-2020, 05:46 AM
This is going to be the chassis for the crane
Tags
hiab, loader crane
