Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
is that the motor pinion Bo?
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
NRS91. No, it's the first gear 13T gear with 300+ hours of runtime. still worked fine, I discovered the wear when I did maintenance. Figured it was time to replace before mayhem occurred. The gears have different pressure angles also, go figure. one has 14.5 degrees and the other has 20 degrees, Soft aluminum, and Glass fiber reinforced nylon. not the best combination I've seen.
[IMG] ![]() Going to change that soon, very soon. ![]() |
Wow how odd!!
That gear also holds the input gear that runs against the pinion doesnt it?
![]() Last edited by Bo Wallen; 01-16-2021 at 02:36 PM. |
Got a B-Train from Ian Gee in the UK. Now to put my Bo-Dog touch on it and haul a$$.
[IMG] ![]() [IMG] ![]() Change the wheels and move the support legs back a bit. [IMG] ![]() I have the fifth wheel mounted forward for a better center of gravity and steering. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() That's that for today. See ya later. ![]() Last edited by Bo Wallen; 02-06-2021 at 09:58 PM. |
Oh! I forgot the Powersupply containers I'm putting together also.
[IMG] ![]() They will supply conveyors and screeners. |
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
