Old 08-06-2020, 10:13 PM
Default Re: Magom hydraulics for Huina 580
All radios are basically the same when it comes to mixing... master - slave then + - values in correct order so pump motor turns correct direction to produce pressure... it’s here where you can lower values from 100 so pump doesn’t rev up.
I use Spektrum, I have boom up always rev whether mix on or off bc I need the speed & power to fill two cyls. Boom is on throttle ch, if I want different reactions for stick throw for different digging styles, I use throttle curve on a 3 pos.
With dual rates you can alter stick throw on rudder, aileron, eleveron using a 3pos & play with expo & offset to manipulate stick throw faster/slower.
I use a 3pos for rudder (house rotation) & combine aileron & elevron together on a different 3pos.
