Old 08-28-2020, 06:37 PM
Default Re: New Project
That sucks, I was afraid the cab to trailer looked very close for things like turning and bridge transitions
It might be worth trying to slide the front axle mounts and cab forward instead of moving the 5th wheel aft past the axle.
Just remember, if you make a series of evenly spaced mounting holes around the misdrilled and correct hole location it looks like you planned for the chassis having adjustibility.
Same thing with extending the opening and putting a radius on all the corners around the t-case cut out.
Looks like it's really coming together!
