Old 09-08-2020, 11:47 AM
Default Re: Landoll 455
Very impressive trailer!
Where do you plan to hide the electronics in that?
Old 09-08-2020, 12:15 PM
Tagaxle's Avatar
Tagaxle Tagaxle is offline
Tagaxle is on a distinguished road
Thanks frizzen,
To simplify the model, I will be actuating the trailer from the tractor receiver. I will have two servo leads from the linear actuators, one for the sliding ESC, main battery power, and trailer lights through a connector to the tractor. I'll utilize as many common grounds as I can to reduce the number of connections. The trailer neck is hollow in the center to allow me to run the wiring forward. The linear actuators, slide motor, and ESC are all hidden under the trailer bed.
Tags
455, axle, landoll, sliding, trailer
