Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
I have some ideas for the fittings. I have several of these brass faucet valves in the scrap bin that have 3/8” compression fittings. Most barbed fittings for tubing have a tapered pipe thread. The compression fittings have a regular 9/16-24 thread which should make it easier for me to modify the length for a more scaled look and fit rubber washers for a good seal. For the steamer blind caps, I’ll try soldering a plug to close the hole in the nut, then turn it round on the lathe and add some lugs. For the female hose fittings, I’ll solder a barb fitting. I also ordered a 9/16-24 die so I can either make the male ends from bar stock or cut the male thread off the valve body and solder a barb fitting to it. At least that’s the plan for now.
![]() The last couple of weeks I spent a lot of time playing around with battery placement, motor/trans location, tilt cab hinge and new floor design all while keeping the cab interior somewhat to scale. I think I finally have a plan to move forward, so hopefully I can start posting some pics soon. |
Finally making a little bit of progress. The cab will be lowered, shifted forward and lengthened almost 3”, so I needed a new floor. After a lot of trial and error, I ended up using 1/8” ABS.
![]() ![]() ![]() I’ll need four more seats, so I may try casting them using fast cast resin. ![]() A coat of white paint for the pink shocks. ![]() Finished up the hinges for the tilt cab. ![]() I’ll eventually attach the cab to the floor with a few screws, so the entire assembly will tilt. ![]() |
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
