One end of the pin will look slightly smaller as you look at the side of the shaft, you might need a magnifying glass to tell sometimes.
I keep a scrap piece of 2x4 handy with a hole drilled drilled in it, when I need to drive a pin or something out I just put it over the hole and rest the shaft on the 2x4 and tap on it.. A simple pin punch https://www.amazon.com/Mayhew-Pro-21.../dp/B00065UJWS It's used to drive out ...pins... |
Currently Active Users Viewing This Thread: 32 (0 members and 32 guests) | |
