Old 09-23-2020, 06:33 PM
Default Re: Huina servos disassembly
If you've got them, something like a Dial caliper or Micrometer are easier ways to tell if it tapers. It would be subtle.
Pins can be reused as long as they fit tightly.
If it's a tapered pin, they are much happier with a tapered hole so that it has full contact everywhere. Straight holes with taper pin give a lot of contact pressure in 1 or 2 spots, then with use something deforms and the joint loosens up.
Currently Active Users Viewing This Thread: 45 (0 members and 45 guests)
