Old 12-08-2020, 01:46 PM
Default Re: double ended hydraulic cylinder
They exist, but it's probably going to be a scratch build, or special order from someone that makes cylinders?
'Double ended' or 'double acting' seem to be your keywords.
Are you going to run it with a hydro pump and valve block, or make a bracket with a pair of cylinders mounted opposite each other with a servo directly giving fluid & space?
Old 12-08-2020, 02:07 PM
frizzen, that's not a bad idea, i was thinking of a cylinder with 2 ends that move and the center stays still, but 2 single cylinders mounted to a central pin might work as well, although more complicated
---=--- vs --=- -=--
