Old 12-08-2020, 10:14 PM
Jared Jared is offline
Default Re: double ended hydraulic cylinder
I think Frizzen was suggesting instead of using a pump driven system, you could use a servo pushing on a separate cylinder to drive the steering cylinder/s, sort of a master and slave setup. They would have to be equal displacement, or close to it. It would in effect be a remote mounted steering servo. Bleeding the air might be an issue, though.
Using two steering cylinders is certainly possible, though. I built a hydrostatic steering system on a 1:1 Farmall tractor with two cylinders that I'm very happy with.
Old 12-09-2020, 08:06 AM
not a bad idea either, but takes up a lot of room. i saw one guy did cable steering that looks pretty realistic
