Old 12-21-2020, 06:57 AM
tessen's Avatar
tessen tessen is offline
tessen is on a distinguished road
Default Re: Liebherr R984 1:14
thanks, i don't know what part you refer, but all the lower superstructure weighs about 15 Kg
the last photos and one test video
https://youtu.be/ZSXQkJDTfbQ
https://www.youtube.com/watch?v=DQ55BgwHt-Q
this is the counterweight of the machine, this is only the model 3d printed to obtain the final part from casting
The first thing to decide is the material, in this case I have chosen to make the counterweight, lead, by weight it would be totally out of scale, but I want to give a certain touch of "forcefulness" to the machine, besides, to remove there is always time
next part, letters and details, at this time i thought to use 3d printed part, but sure i have troubles in cast, no way, plan B
the cast
I have to pause.. a little problem
a rebob (i don´t know if is the correct word, a superficial fail) i have to repair, first i have to prepare the surface and after use a epoxy putty to fill the fail and and a lot of sanding by hand...
... or not, better to use the machines
Last edited by tessen; 12-21-2020 at 08:06 AM. Reason: some post in the update has been disappear, i trying to fix it
