Old 12-21-2020, 07:05 AM
tessen's Avatar
tessen tessen is offline
tessen is on a distinguished road
Default Re: Liebherr R984 1:14
another piece, the arm
are made of steel ribs cut with laser and welded together with MIG
the previous piece need on both sides spacers, made of brass and using sand casting technique, those part are glued with epoxy to the main body, but it´s not important, once time in place, can´t move
and after machining
now the part that hold the bucket hydraulic piston (made of brass) in the arm
and all the pieces that form the arm
this part is a rock protector in the lower side of the arm
and the final piece (almost)
Last edited by tessen; 12-21-2020 at 08:19 AM. Reason: some post in the update has been disappear, i trying to fix it
