Old 01-11-2021, 08:56 PM
Default Re: New Year--New project
The gear box just slides right in, where the axles come out for a different gearing I filed down that "nub" so it slides in snug. in the gap under the axle I'll probably just use black silicone to fill it in, that should seal it and if I need to take it out I can just cut it away. I went this route because if I ever need to go to servos I can since I didn't cut this up to bad.
I was planning to bring the charge port up thru the floor in the drivers compartment right next to the master on/off...
Winch you say....mmmmmmmm
