that truck with the frame lenght it has now looks really good
![]() just cutting the sleeper off really improved the looks keep up the good work
christoffer heavy equipment is my life To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Great start on the daycab! When I built one, I too was looking for a solution to get access to the battery and turn the truck on... I didn't want to chop and hinge the hood, so I looked around at what I had... and I used the rear door from the sleeper. I cut it in half and glued it back together... a lil sanding and body work and you're good. I got this idea from Ed.
![]() ![]() ![]() ![]() what are the plans w/ this rig???
"If you build it, they will come" East Coast Mini Truckers To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Same way i did my first daycab, 'cept i got my idea from myself. ![]() This was clear back in '05 ![]()
Rick.--- I suffer from Wedicosis ------------- My other truck is a Komatsu To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
![]() ![]() Quote:
Score and snap method that i use on all flat pieces i need to cut.
