Old 02-04-2021, 11:53 PM
Default Re: Peterbilt 6x6 Medium Hauler
I see your tie rod in front of the drive axle, it should be behind the axle, it will steer far better behind.
Old 02-05-2021, 02:40 PM
Tommy R's Avatar
Tommy R Tommy R is offline
Sorry if this is a double post. I swear I replied yesterday, but didn't see it.
Anyhoo...
Originally Posted by NRS91 View Post
Looks good, perhaps if you have someone local with a 3D printer they can make you some wheel spacers/shims? I know you can barely see the nuts but a spacer would look better and hopefully make it easier to keep all your nuts tight!
Im based in the UK but can help if youre interested, keep up the good work!
Thank you so much for the offer! I do have a local friend who offered, but felt the nuts were a simpler solution. However, I would prefer a slip-on spacer that's printed provided the thickness can be held consistent.
Thanks for the input. I considered that, but my current knuckles don't provide for that. I would need to also move my drag link behind the axle, which would complicate things. So I'd either need to get a side mounted steering bell crank or fab up a bracket to keep the drag link up front and the tie rod in the rear. Not saying it won't happen, but it would take a bit of work.
Currently, my limiting factor on steering throw is the outside wheel. The knuckle kits the axle at full lock. However, if moving the tie rod behind the axle increases the Ackerman significantly, I could certainly see if providing a nice benefit!
Old 02-05-2021, 03:11 PM
NRS91 NRS91 is offline
NRS91 is on a distinguished road
You did reply, not sure where its gone though!
Some off road racers use reverse ackermann to help pull the front end around so for an RC it would be nice to have correct geometry but not critical, it may even help stop the double drive rear end pushing straight offroad?
Thanks
Nick
Old 02-05-2021, 03:24 PM
Tommy R's Avatar
LOL, after I posted the new message the old one appeared! So I deleted it.
I just did a little test and it does appear putting the tie rod behind the axle results in more Ackerman which would turn my inner tire more than the current setup. I think my limiting factor would be the dog bones in the front axle shafts. I wish CVDs were still available for TLTs. I think I found some in Germany, but they were too pricey and I couldn't justify the cost.
Old 02-05-2021, 04:53 PM
Yea ive been looking for CVDs too but no joy!
Thanks
Nick
Old 02-06-2021, 04:22 PM
Sometimes you need to refresh the page to see recently made posts.
Old 02-08-2021, 11:39 PM
Tommy R's Avatar
Got a nice delivery of Lesu goodies today, but the only pic I have so far is the micro servo mount for the transmission. I drilled/tapped a bunch of holes on the chassis today for the other stuff that came in and all of it should get paint tomorrow.
Anyway, here's the servo installed. With the servo arm cut down just a bit it clears the bottom of the sleeper cab. I just had to clearance part of the crossmember for the shifter link.
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
