#881
is that the motor pinion Bo?
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#882
NRS91. No, it's the first gear 13T gear with 300+ hours of runtime. still worked fine, I discovered the wear when I did maintenance. Figured it was time to replace before mayhem occurred. The gears have different pressure angles also, go figure. one has 14.5 degrees and the other has 20 degrees, Soft aluminum, and Glass fiber reinforced nylon. not the best combination I've seen.
[IMG] ![]() Going to change that soon, very soon. ![]() |
#883
Wow how odd!!
That gear also holds the input gear that runs against the pinion doesnt it?
#884
![]() Last edited by Bo Wallen; 01-16-2021 at 02:36 PM. |
#885
Got a B-Train from Ian Gee in the UK. Now to put my Bo-Dog touch on it and haul a$$.
[IMG] ![]() [IMG] ![]() Change the wheels and move the support legs back a bit. [IMG] ![]() I have the fifth wheel mounted forward for a better center of gravity and steering. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() That's that for today. See ya later. ![]() Last edited by Bo Wallen; 02-06-2021 at 09:58 PM. |
#886
Oh! I forgot the Powersupply containers I'm putting together also.
[IMG] ![]() They will supply conveyors and screeners. |
#888
Looking good Bo!
That B trailer is really neatly made!
#889
Thanks, NRS91.Yes, it's very well made by Ian Gee. Now ready for some shows.
[IMG] ![]() |
#890
Hopefully you will be able to come back to the UK at some point!
#891
Thanks, Yes I will get around when the coast is clear. I guess the weathering comes automatically. Travel in suitcases will take care of that. I hope the UK in July is a go. and Holland in September.
#892
Kerst |
#893
Thanks, Kerst. Backing up is no problem. It's fun, and I like good challenges.
#894
#895
Great looking rig!
Any idea if those sea cans were production, or homebrew?
#896
Thank's Frizzen, Hercules Hobby Cans, and trailers. Assembled and painted by Ian Gee UK. Tweaked by the Bo-Dog
#897
Busy Busy Bo, looking good
#898
Thanks, Joe. Yes, I've got the urge back to move a few projects forward. How much forward resume to be seen. The logistic side of the fleet has to be in shape A.S.A.P. Here are a few pics of the doings.
Put more bolsters in for centering 32500kg 20-foot container in the proper position. [IMG] ![]() Box trailers need some tuning and proper ride height. This is just a mock-up to find the look. [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() Last edited by Bo Wallen; 02-21-2021 at 08:11 PM. |
#899
Are the heavy haulage fleet getting reworked into general haulage now Bo?
#900
NSR91. No, they will stay Heavy Haulers — 4 new trucks coming for the general haulage. I used the Heavy dudes for the mock-up only. I needed to reassure to get the measurements in order. Now off to the cut and tap department.
Currently Active Users Viewing This Thread: 24 (0 members and 24 guests) | |
