Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
#921
This is the turntable bearing I use.
40x60x3mm size suits the tamiya chassis width nicely www.amazon.co.uk/gp/product/B07GCCTF61 I use it instead of a fifth wheel on my tandem axle dolly as I have a hinged drawbar.
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#922
It could be fun with a Christmas card from Tamiya
![]() ![]() NRS91. Good Idea. That's what I'm doing. While I figure how to secure for driving around and break them apart for traveling, I'm making BabyMoon hubcaps. [IMG] ![]() The build can start. ![]() |
#923
I have a Keyhole shaped hole in the centre of the turntable so you slot in then pull the dolly forward to lock it in place then it is secured with a slide in "blade" that slides across in front of the king pin
#924
Would those hub caps work for regular duallies too?
#925
NRS91 Good idea, I will try that. Emil, Yes......sort of. The caps come in a huge variety, Some hardware stores Lowes, and Home Depot have them. I get them from this company: http://www.pro-dec.com/screw-caps-sc.../8-8-snap-caps They have a bit low profile and sit a bit high caused of the axle and lock nut. I put a dab of plumbers putty inside and press them on. the putty stays tacky over a long time, so they stay on.
[IMG] ![]() [IMG] ![]() |
#927
Looks good!
Kerst |
#928
Looking forward to see you parallell park in real life
#929
Bo-Dog, I LOVE them hubcaps! They're gooder than the 3D printed ones I've seen, in that they look more realistic.
#930
#932
The center beam ar in place for the GullWing doors.
[IMG] ![]() |
#936
![]() Last edited by Bo Wallen; 03-17-2021 at 04:44 PM. |
#938
nice work Bo!
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
