Old 04-28-2021, 07:12 PM
Default Re: Ram Build
If you can bring in the wheel offset, or narrow the tire, it would probably help the amount of stuff rubbing up front?
Its hard to see in your pics, but if you're wanting the next step lower from there, try going to Spring Under Axle with the Lifted setting on the 'not a shackle'. You can fine adjust the fixed side of spring with spacers back up.
