Old 06-01-2021, 09:34 PM
Default Re: Landoll 455
Originally Posted by Tagaxle View Post
Thanks, the trailer itself weights about 15lbs and can probably handle an additional 30lbs of load. The trailer being all aluminum will handle a pretty good amount of weight on it. The weak point is the stock Lesu trailer springs shown in the pictures above. They are fairly soft, I might try and find a stiffer set to increase the load carrying capacity.
Or....perhaps take a tine from the lawn rake, & transform it into some helper springs to stiffen the ride a bit.
Tags
455, axle, landoll, sliding, trailer
