Old 06-03-2021, 02:20 PM
Default Re: Switch question
Has Dimension Engineering stopped offering the Pico or Battle switch?
What are you attempting to do with it?
Any small 10A esc would work the same as a DPDT switch, just takes up a little more space than the DE switches.
Old 06-03-2021, 03:21 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
The Pico and battle switches are still available, but to the best of my knowledge, they're just 2 position switches (on/off). Using a 3-position switch on my transmitter, I want to activate a solenoid valve when I throw the transmitter switch in one direction, then activate a different load when I throw the switch in the other direction. In the center/off position, both loads are off. For now, I'm mounting two roller switches next to a servo and will use the servo horn to activate the switches, but I'd like to find a simple electronic solution so that I don't have to worry about aligning/adjusting the roller switches.
