Thanks, y'all! Now I'm looking for some small die-cut graphics and then the body will be done and it'll be on to other things to finish....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Since space in this thing is rather limited and I plan on running a Beier sound unit, I ran out of space for the battery. I was hoping to avoid it, but I had to resort to building a "toolbox" to house the battery, a 3s 2700mah. It's made of styrene with a diamond plate veneer.
![]() ![]() ![]() No brake lights or housings were included with the kit so old Axial parts to the rescue! ![]() I just need to figure out how to cleanly route the wiring. ![]() Got the shifter installed and figured I'd give the driver some comfort and convenience a 20th century truck driver has come to expect! ![]()
Ugh. So despite making the battery box as low and short as I could it's simply going to interfere with the nose of the trailer on anything, but the flattest of terrain. And since this thing is 4 wheel drive, I expect it to see its fair share of undulating terrain. So I have to figure out another plan. Here's what I'm dealing with....
Space under the hood is limited. Keep in mind there's a motor and trans in the middle. ![]() This is the stuff that needs to find a home in the truck. ![]() The speaker was intended to go here, under the bench seat. ![]() Battery is just too thick to fit in there so a new battery would likely be needed if I put it here. ![]() I'm still messing around with component placement and I'm sure I'll come up with something decent.....eventually! LOL
