Old 09-19-2021, 04:46 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
Default Re: Seagrave Tanker
It’s been pretty quiet lately, so I figured I’d post a couple quick pics.
I originally planned to mount all the relays and bus bars directly to the body, but that quickly became a pain every time I had to remove the body to figure out my next move. So I decided to take this mess:
and mount everything to a couple of free-standing shelves attached to the frame. This allows me to remove the body without touching most of the electronics.
Getting started on the rear body panels
Old 01-06-2022, 09:43 AM
This build is based upon a new tanker that my department is purchasing. We recently had to switch to a new manufacturer (Ferrara), so I had to make some changes to the body. From this
to this
Before working on the onboard water tank, I had to make the portable pool and its storage compartment.
The compartment door will be held in place with some 1/8 dia magnets in the door and sides of the compartment.
Old 01-26-2022, 04:35 PM
Default Re: Ferrara Tanker
I started working on the water tank. It’s made from 1/8” ABS sheet and will have a dump valve and motorized chute that extends out of a back compartment for filling the portable pool.
Space around and under the tank is limited and I couldn’t find a ready-made valve that would discharge the tank quickly, so I’m making one out of delrin. It will sit inside the tank and be activated by a solenoid on top of the tank that lifts the plunger.
The inside tank bottom is sloped to promote drainage.
The tank just sits on the frame rails. I’ll probably strap it down with velcro so it’s easily removed.
Here’s the screw drive for the chute mechanism mounted to the underside of the tank. I’m still waiting on resistors so I can remove the potentiometer from the servo. I also need to hook up another switch to activate the dump valve solenoid when the chute is fully extended.
Here’s a video of the chute. I’ll see if I can make the chute open the compartment door to be added later.
https://nam11.safelinks.protection.o...amp;reserved=0
I’ve also been learning Arduino so I can program the flash patterns for wig-wag headlights, an arrow bar for the back of the truck and all the warning lights. If I get ambitious, I’ll try to figure out how to change the arrow bar remotely, but for now I’ll just leave it with the center pattern. Here’s a video.
Old 05-31-2022, 04:43 PM
I pressed some brass electrodes thru the side of the tank and created a water level sensor using some transistors, resistors and LEDs.
Also added a fill tower to the tank.
Siren speaker mounted between the front frame rails.
Printed the front bumper skin and added hose troughs, tow hooks, fake horn, and gated wye.
Old 05-31-2022, 05:30 PM
Testing the deck gun and dump chute with the tank installed.
https://youtu.be/7jWDDmgtoq8
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
