Old 01-18-2022, 03:44 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: 1/10 Mining Dump Truck
Originally Posted by Zabco View Post
Sounds like you got into this hobby for the same reason I did, learn new methods and techniques.
Indeed , thats my intension.
After this Milestone, I've got the motivation back to weld all the beads on the trough (endless small sparks in .8 second rythm) and improve the strength of the frame.
Frame and struts are real scale. Always fascinating what a few pieces of sheet metal doing with the stability.
Meanwhile the tires arrived.
Bespoked fabricated. Full, hard Rubber.
The enormous wheigth...
.... result in exact 8 kg for the completed rear axle.
I think it looks quiet nice
rims made
and a little stack of wheel caps too
As a little intermezzo the non-functional fuel-tank was done
Regards
Ralf
Old 01-18-2022, 07:02 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
Very nice fabrication! That is one solid looking truck!
Old 01-19-2022, 12:15 PM
Thank you.
Making the front axle was much more complicated as the rear axle.
Due to the great weight i need a real brake. the esc hillbreak wasn't enough to hold the little monster. The motors in the rear axle prohibit any break in them.
Ergo the front axles must have breaks. The original has drum brakes. Consequently I plan my first drum brake in my life. That was a real exciting phase of the build.
The axles body is from stainless 30mmx3 to hold the steering cylinder, three links and the panhard. The space looks wide but, as usual, at least I've to fight for every mm.
The c hubs are made from aluminium.
All sizes and shapes, except the hydraulic cylinder, are scale.
the c-hubs gets 3° tilt to prevent understeering
Flanges are from 4mm stainless....
....or some more mm
Links done
overview and end of the simple part of the axle
Regards
Ralf
