Old 01-20-2022, 12:33 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: 1/10 Mining Dump Truck
Originally Posted by bigpipespete View Post
Nice work , you should be proud of yourself.
Thanks. I am
The complicated parts of the front axles needed intensely research and planning time. Enough time for painting. Not my favourite task. But sometimes it has to be
Bored from painting, i've made the baseplate for the Front
(1mm stainless)
Planning has closed and the work begins.
Milling the Joints from stainless
After some tests about steering radius etc i've to shorten the steering cylinder. So i've take the opportunitiy and build it a bit more scale. later you will see nothing from it, but i know, it's almost scale.
changed cylinder needs a changed flange. from
to
at least mounted and covered from a heavy duty skid plate
Regards
Ralf
