Old 01-22-2022, 12:31 AM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: 1/10 Mining Dump Truck
Drum Brakes.
some stainless sheet , 3mm thick, aluminium for the drums and some 6x1 stainless pipes
the square sheets are turning into round and welded together with the pipes
welded onto the joints
first tests. all things going well.
i need stops on the axles to prevent the drum from contact with the baseplate
a lack of suitable stainless washers forces me to made my own
small pieces of a 1mm sheet
turned together to the od
et voila
welded on position
in the their front , the drums has holes to hold two bearing and a spacer.
in the back the big hole for the brake pad holders
put on the axle, the drum fits well and has no contact. the double bearings are strong enough to avoid tilting.
A good start into this chapter.
Regards
Ralf
Old 01-22-2022, 03:05 PM
Drum bakes: Brake pad holders.
aluminium round
simple method to hold the round parallel to the middle
sawed and milled
brass bolts
fitted with springs
set up
a little problem are the brake pads themself. after a lot of research i've found the tip that gasket paper (abil eg) was a pretty simple material
and really: it works perfect.
mocked up
next and last part: bowden cable and the mechanics to activate the breaks.
Regards
Ralf
