Old 01-23-2022, 12:24 AM
cooker2003 cooker2003 is offline
cooker2003 is on a distinguished road
Default Re: 1/10 Mining Dump Truck
Real drum brakes even! Impressive!
Old 01-23-2022, 12:49 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Thanks.
I need two different actuators for my breaks, like the big ones I need a driving and a parking brake.
But i won't two bowden cables. Therefor i've made a central platfrom between the frame. Later truly invisible.
A simple sledge to hold a constant direction. left to the actuators . right to the drums.
the testing arrangement was simple and ugly.
that must be prettier.
to get a weldeable bowden tube in my tiny sizes was impossible. so I've bought
a really small tube stainless
Regards
Ralf
Old 01-23-2022, 01:20 PM
bending such a small tube
An inlay from 1mm brass rod was the solution
Bending worked wonderful smooth
but i need not a ring but four 90° parts.
inner deburring with a small ball end mill
and welding on the screw wich hold the axle onto the c-hub
to avoid length-changing while steering.
On the other side, a servo and a small n20 gear motor has taken their place.
together with two end switches for the motor, they are the rest of the mechanics.
A short clip of their work, you can see here
Regards
Ralf
