Old 01-24-2022, 02:11 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: 1/10 Mining Dump Truck
Well, after planning, the doing was a simple turning job
the guard rings are very small.
seals are simple o-rings
big thread on the lid
Fits perfect
To lock the trough in open state for working on the hydraulics are at the big ones simple Us wich will hook on the back plate.
So do i
Works
Here you can see the last part of the cylinder with the flange. both from stainless to be able to weld. All other parts are from aluminium.
the original have a maximum tilt angle of 53°.
almost
later, after some test and measuring, i'm able to raise the size of the guard-rings. that brings a lot more stability.
Regards
Ralf
Old 01-25-2022, 04:03 PM
Last post so far
The exciting parts are done. Followed by things i have to do.
Hydraulic arrangement
Many stainless sheets .3mm or .5 mm are cut, bend and welded to build the front.
The bonnet is parted.
on the back the massive airfilters
tank
battery tray
after all the yellow some belaz blue
and, tradional for me, the last thing: The cabin
Et voila. Almost completed
Actually the one and only clip with my Belaz 7540 Mining Dumper working.
(Don't mind the unscale Loader )
Here it is
Now it's waiting for Spring to make a better clip and get some interieur into to the cabin.
Thanks for your Interest.
Maybe you'll watching my thread to build a more scale Loader
Regards
Ralf
