Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Scale Buildings, Warehouses and Structures.
Scale Buildings, Warehouses and Structures. If you have buildings and other structures that you have built to use with your Rc's here is your place to share them.
Old 04-08-2022, 10:12 AM
Default Re: Wanco vertical mast arrow board
Thanks again man! This is a really sharp trailer.
I'm not great at backing trailers in RC, so i threw on a tongue extension link. Not playing that in Expert Mode. (Erm wait, i mean "So that i can use it with other trucks that have more overhang past the hitch")
I soldered a couple chunks of brass box-tube into a square, made a crossbar so it can hinge at the board. Punched some wire holes under trailer. Roughed and epoxy putty the mast to trailer. Dropped some phone-cord through to get blinky and direction up top with On/Off and Right/Left switches down at battery box.
Once I got to that point decided before i paint the mast, i probably needed to make a lever on the mast with a linkage to move the board between Vertical / Horizontal.
Somehow it stalled again at: cut a slot in mast, solder a 90 to bottom of board, drill a couple holes, insert a couple pins and run a linkage.
Part of me wants to find reference pics to do it 'Correct' style, the other says Just Send It! If board goes up/down happy you're good, bonus if it latches.
