Go Back   RC Truck and Construction > R/C Boats > Boats!
Boats! Here is a place to show off your boat.
Old 04-14-2022, 10:47 AM
Default Re: RC Benchy
Take a look at this and see what you think, has Benchy got a Cap'n? (I think so.)
https://lh3.googleusercontent.com/pw...-no?authuser=0
Here's a slightly blurry side view.
I printed Mario out at 100% and stuck him in the wheel-house, he was just too small. I reprinted this version at 120%, which I think looks a LOT more better. I think he's going to have to go under the knife and have a little surgery on his right arm though. To make it look more like he's holding the wheel, and less like he's just standing there like a Dork.
Benchey got several other modifications. He got his Close In Weapon System, his smoke-stack was modified to be a radome, and he got his diesel exhaust stacks. I originally had a really neat set of barrels designed for what was supposed to be a Mini-gun. I took one look at the printed version, realized that they were WAY TOO SMALL, and said - "Nope, not gonna happen." The Mini-gun then got replaced with the chain-gun seen in the picture. As you can see this is not just a Close In Weapon System, it's a REALLY Close In Weapon System. In fact it could be used to pick-off the seagulls and keep them from crapping on top of the turret. I've got some seagull figurines on order to set up just such a scene.
I've got to get some more hardware, motor, ESC, prop, bearings, prop-shaft, rudder-post, and all the other Bit's and Bob needed to make a functional boat - that I haven't already got stashed away somewhere.
Then Benchy will be almost ready for the test pond, and his weights and balance testing. Painting will be done after that.
Don
